1G Top mount mani drain help
Jdevil187
127
14
Aug 3, 2014
Houston, Texas
Can Any of you guys running top mount manifolds share some pictures of your oil drain line? I'm using a Shearer manifold but the way the turbo seats, places the drain line on top of one of the runners. I can get away from the manifold by clocking the drain a little more out, but I'm worried i may blow seals right away.
45* out and around the manifold then a nice long piece of line down to the pan. Top mount manifolds are superior because they give you the "fall" needed to allow the turbo to drain much better than the stock location.
You're better to use the braided line in this situation because of the heat from the manifold being so low...it will insulate the line better and prevent it from burning through should the line accidentally touch the manifold.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
