Top End busting
Drifter27_04
335
Feb 13, 2005
Winston Salem, North Carolina
This mainly happened after finding a boost leak and fixing it...yes it pushing more air but I cant solve the problem.
Check the log and someone please leet me know what is going on. Only happens in the upper RPM's and Boost.
Your front o2 shows you running lean but your wideband and a/f ratio says your pig rich. Could be bogging down and causing rich knock.
Right click. Display values. Add ZT2WB. That'll show you his wideband readings.
Thanks you guys but I think I have some other strange issues. I meet my wife and kids at Myrtle beach last week and while I was down there something happened to the trans, not sure if it is the clutch, flywheel or tranny (hope not). But its parked at my wifes fathers place until next week or two when I go back to finish taking it apart and fixing it but in the meantime I have gotten the busting out part settle but I am still in the need of have it tuned once its up and going again. Its moderately tuned but I want to max my tuning out and get everything dialed in.
Anyone going to be in the Mrytle area in the next coming weeks?
Have you calibrated the wideband to link yet?
It seems like your maf adjustments might be off because your calculated air fuel ratio is so far from your wideband ratio, im no expert though, im just starting to get into link.
I asked what the gauge reads, not what the logged value is. For future referance hitting ctrl+a when you open the log will display all the values they logged.
There is a small chance I might be. PM me when you find out what dates.
