too rich?
desertspyder
Banned Member
101
Dec 24, 2005
29 palms, California
When idling there is a STRONG smell of fuel coming from my car. Also when I crank the car up I get a black spray from my exhaust that covers my driveway. The car has also felt sluggish when accelerating lately. I just adjusted my TPS and set my BISS. My plugs and wires are fine. And I have no boost leaks. Any suggestions?
a good sign of running rich is a stuttering exhaust tone.
if you can taste the gas in the air and smell it..then you proly are running rich.
What plugs and wires are you running? how old are they?
try taking out your plugs and gaping them closer.
also are you venting your BOV to atmosphere? or is it recirculated?
I have a 2 1/2 inch magnaflow cat. MPG has always been worse than I thought it should be but I live with it because I love my car. I have Denso Iridium plugs (carefully) gapped at .027- .028. and Bosch platinum wires. Plugs only have about 4k miles on them Wires only about 500 miles. I'm recirculating my BOV. Earlier today I took out both of my side honeycolmbs and now I'm getting a crappy idle but when I accelerate the car pulls a lot better than before.
You running your blow off valve to the atmosphere probably has an effect on the richness problem. Being that the blow off valves leak at idle, the maf still compensates for that air and put more fuel in, making this a rich mixture. Try hooking up the bov again and see what happens. Also try getting a 1g bov if you dont already. Just get ahold of me for that i have some. Thanks
My friend has that BOV on his WRX and it starts to leak just b4 20psi, so we swapped it back for his arc.
I am just wondering, what kind of fuel pump are you running, it doesn't say in your profile. Also, you should get a logger and log your idle and your cruise to see whats going on.
I keep it at 14 (peak) but of course it tapers off. by the way I'm not venting my BOV to the atmosphere. I'm upgrading to 16G with supporting fuel mods/ datalogger when tax returns get here but I don't think I'll take it over 20psi. Can greddy type s not hold over 20?
K Hill.... That's a good question. Before I gapped them they would (blow out) at about 10 psi. I still get a pop when accelerating from a standstill every now and then. I want the NGK's also.
this may be wrong but i thought that there could be some sludge laying around in your engine. that stuff coud easily spray! LOL
The reason that you're so rich is that this is way the ECU has been mapped from the factory. In order to keep the motor well within a safe zone under boost, the factory ECU runs at a very rich 9.5:1 Air/Fuel ratio and only allows for 16 degrees of timing. Since you still have the stock fuel setup and have made no changes through an EPROM ECU or AFC, you'll still run at this air/fuel ratio.
There's nothing wrong with your car. When you start performing upgrades, it would be wise to invest in either a wideband O2 so you can lean the car out safety, or an EPROM ECU with custom A/F and timing maps. I saw a huge difference simply swapping chips from the stock settings to an 11:1 with more timing advance (I now run 11.7:1 with 19-23 advance depending on what type of gas I'm running).
Let me know if that makes sense,
Andy
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
