Too rich?
flinguist
945
22
Jun 23, 2003
Rockwood, Michigan
I just installed a Walbro 190 LPH fuel pump, and the car doesn't have as much power as with the stock pump. I've got stock injectors. Is this because I'm running richer w/ the walbro? Can this be fixed w/ DSM link (on the way)?
You may be rich w/o a logger you can't tell, with something like a link you can tell if your rich and correct it a little bit.
Are you running stock boost too?
as everyone knows with more fuel you need more air :)
same with more boost(me for example)
when i get up to 15 PSI it almost bucks a little bit(not to hard i know its not fuel cut) drops down to 13 PSI then up to 15 then down to 13
im not getting enough fuel to match how much air im putting in to my engine
so chances are your doing just the oppisite if your not running higher boost
I'm running 15 psig boost. The Walbro pump has a higher flow capacity than the stock pump, so I don't think I'm running lean. The car still runs ok, but it ran better with the stock pump.
These small blips in a fuel curve van be caused by both lean and rich conditions. I was tuning my Safc and when I got going it would blip alittle then keep on going. In my case, it was a rich point. So unless you have a logger of some sort, you are going to be hard pressed to see what is going on exactly.
Hope I shed some light.:thumb:
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
