To anyone who has bought a camber kit!
chris712vt
524
6
Mar 27, 2006
SLC, Utah
Application - 2g, FWD, rear camber
Has anyone bought a rear camber kit from a reputable company such as Ingalls? If so how much spacing did the kit come with, or how much did you use? I was going to stack up washers until i found the right amount to return my camber to about -1 degree. However, now instead of that I'm cutting plugs out of solid steel plate from a local factory and would like to know what thickness to use for my spacers.
Do the kits come with two or three 1/4" thick washers for each bolt, or more like one 1/2" thick washer? I'd just like to know so I choose the correct steel to punch my plugs out of.
Thanks, and I'm about 1.5-1.75" lower than stock.
    • Sdcryan1
