Tmo Graph Log:pretty Close Opinions?
diamondstargsx
86
Dec 10, 2004
sml va, Virginia
HERES A CRUISE LOG:
MODS:
PRECISION 50 TRIM
FIC 650"S
255 REWIRE PUMP
AEROMOTIVE FPR SET TO 38 PSI
MAFT TRANSLATOR:BLOW THROUGH
SPEARCO FMIC
3INCH TURBO BACK APEX MUFFLER
TIAL WASTEGATE
GREDDY BOV
MAGNECORE WIRES
NEW NGK"S BPR7ES
HIGH FUEL TRIM:100%
LOW FUEL TRIM:95%
MIDDLE FUEL TRIM:100%
HERES A 21 PSI 3RD PULL:
RPM:6935
PEAK TIMING:21
PEAK KNOCK:1
PEAK IDC:13.8=78.4%
OPINIONS WOULD HELP!
Add some fuel from about 4k up on the Hi Throttle table.
I have never used TMO, but is it possible for you to display that as individual data points. It's just easier to read. :thumb:
Also, you really only need to log rpm, timing, knock and airflow (if you want). The less you log, the more samples/second you will get.
Enjoy! :D
