TMO help
Kloopofadown
62
Dec 3, 2004
Houston/Galveston, Texas
I have a check engine light for ...I'm not sure. My TMO logger only shows 1990 federal ECU, but under DRB2, ECU info, for version it says "11 Oxygen sensor | 14" and only shows half of the 4, those both are codes the 14 is throttle position sensor. I bet there are 1 or 2 more codes listed. When I click "clear codes" its says unable to clear codes. This leads me to beleive I have a corrupted version of the logging software as I cant view any of the other tabs on DRB.(it gives me an illegal operation box) Could anyone email me their copy of the software? I can email my copy to you first and see if it works correctly on your setup and to prove I'm not stealing either.
I can help you with one of your problems. The 1990 ecu has to be reset to clear error codes, you can't reset them with the logger.
