timing with a cop help
woooop
411
May 25, 2005
lakewood, Washington
How do i adjust the timing with a cop set up and should i just swap in stock coils for a more accurate reading ?
You can lay the pickup on the #1 coil and it should work. Or just put the signal pickup over the wire going into the first coil. And i dont mean you have to grab it up at the coil connector either...back where the wire exits between the VC and cop plate is just as good.
  • Wanted 6 bolt NT water pipe
    • chrisman287
