Help with COP with pictures
wickedz
736
5
Dec 12, 2009
Madison, Wisconsin
So i had to take everything apart for cleaning and plus the previous wires were toast. If someone can help me with how the wiring goes, that would be muchly appreciated. I think its just going to be normal fire order?
Car 95 TSi 5spd
There are tons of writeups on this out there. You just wire the 2 center coils in series with each other, and the 2 outer coils in series with each other. One end of the the series connection is ground, the other is power. For more specifics on how to do this you should use the search button at the top of the page.
This oughta work for the 2g.
:thumb:
Actually the second image is 2g specific, but use the 1st as a reference as the 2nd isn't very clear, the 2g wire colors are different for the OEM plugs.
Thats about how I remember it when I removed it. The #1&#4 were together and #2&3 were together. Just couldnt figure out the coil plug with the 3 wires
