Questions with pictures
kylehlub
56
Jun 28, 2005
madison, Wisconsin
A couple of questions.
1. Turbo is really oily, is this fine?
<img src="http://www.dsmtuners.com/gallery/data/501/53018pic-1.jpg">
2. Some cars have an oil filter here where mine is connected to a tube. Can I also put in an oil filter and just cover up the loose tube.
<img src="http://www.dsmtuners.com/gallery/data/501/53018pic-2.jpg">
3. This tube is not connected to anything. Is it suppose to be connected and where?
<img src="http://www.dsmtuners.com/gallery/data/501/53018pic-31.jpg">
Thanks...
Well for #1 you need to get some new crush washers.
I have no idea what you are pointing to in #2
As for #3 that should hook into your WGA if you do not have another form of boost control. If you do then you can plug the hole in your intake pipe and plug the ports on the BCS.
as for number 2 ..its a breather filter some people put here but don't do it just put a really small fuel filter here in line with the hose and leave it connected.... as for number 3 it looks like the stock boost control solenoid..... if you have a aftermarket boost controller then you don't need the solenoid and just plug it up..... :thumb:
Justin
you should hook that hose up from you wastegate actuator rod to a tee between your intake manifold and BOV.
  • Wanted 6 bolt NT water pipe
    • chrisman287
