timing questions
spic21
240
May 14, 2010
albany, Louisiana
wanted to check my timing so let car warm up then turned it off jump timing wirg to ground restarted hooked up timing light ground to ground pos to pos and to 1 plug wire. (also marked timing notch with white out) (assuming that the -l- line is zero) and then next line five then has 10. my timing is bouncing all around. closest i could get it was bouncing between 5 and 8. what am i doing wrong here. or is this ok.
