timing problem (after rebuild)
SinEclipse
766
Jul 31, 2004
San Diego, California
i just got the engine rebuild with 40 miles on it. for some reason my timing keeps jumping, we changed the tensioner and everything. after we redo the timing it works great the first day but next day when we start it up it just jump again and no start at all. we tried many things and get the same result.
does anyone know what is causing this problem because i am getting piss off at this.
thanks in advance for any help.
well, we decided to do the whole entire timing belt again. check to see if anything is loose. hopefully timing wont go off again in 2 days.
Did you check if you had an undertensioned belt? The way to check is to take the pin or allen wrench that keeps the tensioner compressed and see if it will slide in the hole and through the piston smoothly. If it doesn't go through because the piston went up to far means you belt is undertensioned.
i dont think we did. i'll tell the mechanic to do this since the motor is under warrenty. i got tired of going there checking up whats up so i'll just tell him to do everything to figure out the problem.
tried fixing this problem but i gave up and now it goes back to the mechanic.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
