Spoolin4Ever
- 1,142
- 14
- Apr 24, 2005
Moses Lake,
Washington
Looks like my timing is off a bit. THe bottom end is lined up, but the top is not. Very close, though?
Usually on a car with a decked head or block, the lower timing mark will not be in the exact center of the notch anymore. As long as the crank timing mark is in the notch when the cam marks are exactly lined up, it's as good as you will get. Usually the mark on the front cover will be almost at the edge of the notch on the crank plate on an engine with a decked block and head. This is because the head is now closer to the crank centerline, and this causes the cam timing to be slightly retarded.
FInally, I noticed if I torue the pulley center bolt to 32 lbs. it might want to change the tension. Is it really supposed to be torqued to 32 lbs? Seems like alot. I need to go look in the manual. But the guy that did the 6bolt/2g thread said to tighten it to 32 lbs.
Yep, damn oil pressure!
Glad you got it sorted,
