Timing Mark Not Steady...
TurboBlue
654
Oct 25, 2002
Canton, Connecticut
Well yesterday i was testing out my knock sensor by watching the timing mark and hitting the block with a hammer. Found out th eknock sensor is indeed bad. But the weird part was, that even afterwards, while looking at the timing mark again, the mark never stayed right at 5 BTDC, it kind of swayed back and forth a few degrees in either direction. Anyone know whats causing this?
Unless you have the check timing connector grounded the ECU is going to adjust the advance as it juggles the various parameters to keep you engine running.
Also keep in mind that the knock circuit is smart enough to to only pay attention to the sounds of knock when ignition knock is likely to happen. The ECU has crank angle information and knows than no ignition knock is going to happen when a a piston is halfway to BDC. So pounding on the block with a hammer isn't a really good test unless you get luck and hit at just the right time and make the right noise.
Steve
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
