steve
DSM Wiseman
- 17,447
- 4,149
- Feb 3, 2002
St. Charles,
Illinois
Will it be safe to plug my ecu and turn the key to on to test the sensors? Seems like I would fry my computer again doing this.
Also you will have to tell me how to use the volt scale if you would please.
I havent gotten my next ecu yet so I cant test until I get it.
Without knowing what your frying on the ECU's I can say what's causing it. Ask whom ever your sending them back to what getting toasted.
In order to tell you how to use the voltage scale(s) I need to see what you have. Some multimeters have one setting and autorange while others have multiple voltage ranges and you need to select the correct one for the max voltage you expect to see.
The red probe should to to the positive test point (usually the pin we want to measure the voltage of) and the black probe to a ground point. The meter will then tell you the voltage potential between the two. If you put the red probe on the battery positive terminal you should read about 12.6v with a good charge and the ignition off, 14.4 or more when the engine is running, and perhaps as low as 10v when your cranking as an example
As long as your not connecting two pins together while measuring it's pretty safe to measure the voltage on any pin. You however don't want to set your multimeter to the ohms scale and try measuring powered lines. It can worst case blow up your meter.
Steve
