2G Timing Gear Adjustment Issue
mnetwork
1,017
Feb 25, 2006
New Milford, New Jersey
So I finally am adjusting my cam gears. I started off with +4 and -4 (exhaust/intake). Adjustment went fine, but now I'm getting noise (a whine sort of) from the cam gear area and my timing belt is tighter than it was before. Is it possible the belt is tighter now and causing noise? If so, how would this happen? Other than this the car is fine.
Personally, if I had any doubts I would go ahead and just pull the timing cover and verify correct tension by measuring the hydraulic tensioner rod.
I don't know if adjusting the cam gears affects tension but your description suggests that it might. You've got me curious about this now.
It really would make zero sense to me. I just loosened the nuts on the gear and turned the cams 4 degrees each using a wrench on the cam gear bolt.
  • Wanted 4G63 800cc injectors
    Im looking for a set of injectors that are at least 800cc. Thanks!
    • DSM_Thorpe
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
