afpr adjustment
95gstnotwalkin
Nov 1, 2004
bowie, Maryland
i am going to be puttin in my full throttle afpr this week and i was wondering how to adjust it or waht to adjust it to and how it really works that sort of stuff... DO i need a gauge on it ?? thanks
They are very easy to adjust, just loosen the locknut on top then turn the stud in or out to adjust your pressure accordingly, then retighten the locknut. You will definatly need a gauge to accuratly adjust the pressure, and also a 90 degree elbow to point the gauge so you can see it clearly and so it will fit in that tight space under the hood. I just put mine on a couple weeks ago, very simple to install, just be sure to use teflon tape on all your connections and tighten everything up good. For a 2g, you should set the fuel pressure to around 42-45 psi with the vacuum line disconnected, then reconnect it when you have the pressure where you want it. :talon:
