timing belt question
Sicotic
278
May 26, 2009
fairbanks, Alaska
will a 95-99 timing belt fit on a 89-94? i have a 2g head with a 1g block any answers? tried to search came up nothing,
I believe the 6 bolt and 7 bolt motors have different timing components so if you were to buy a timing belt "kit" it would come with 6bolt/7bolt specific components. The timing belt is the same from 90-99 for all 4g63's though. You should be fine.
Pete
In which case you should be all set. Go with an OEM belt if anything.
Pete
