420A Timing Belt Problems
There is a good write up over on 2gnt:
www.2gnt.com/index.php?d=Timing_Belt_Replacement
If it’s your first time ever doing a timing belt job it will be time consuming. I also suggest getting a new water pump and all new bearings. There is also a kit that changes the hydraulic tensioner over to a mechanical one. I made this switch several years ago. The mechanical one is much easier to get the timing dead on.
Rock auto has kits that include everything. You can go either hydraulic tensioner or mechanical.
It will be a good project for you. Consider new cam and crank seals, and the water pump so you take care of all your leaks and have a completely refreshed system that will be good for a long time. I even recommend a new harmonic damper. If you look at yours while its running and you see any evidence that it isn't turning true or wobbling, replace it. That was what went bad on my gst and dug back into my timing belt causing the belt to jump, the valves to it pistons, and had to get the head rebuilt.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
