Tighten the gas pedal...
Mitxubishi
45
Mar 9, 2005
La Grange, North Carolina
Wonderin wots the easiest way to change the resistance on your gas pedal? Im tryin to tighten it done...
Adjust the throttle cable at the throttle body/intake manifold. You'll see the bolts there that you'll need to loosen in order to adjust the cable.
