talontsi97
- 194
- 0
- Nov 12, 2004
Pennsylvania
I will be getting a Evo3 16g when i go to do my turbo upgrade, with supporting mods.
I have a question about using a external wastegate on the turbo. A local guy is selling a ported evo3 exhaust manifold and o2 with a Tial 40mm external wastegate mounted on the manifold for 500$$. I was just wondering if that would be alright for that turbo. Is it to much or any problems with running that? I have a Apexi n1 downpipe which i think is 2.5" and a 2.5" test pipe and Apexi n1 cat back already jsut so you know what exhaust im running. I plan on having the turbo ported to when i buy it.
Is there anythign wrong with this setup up or anythign i should now about. I am still somewhat new to all of this but i was figuring i can buy the manifold and o2 already ported by a good shop in the area and if it already comes with the wastegate then its good caus ei have seen someone run a external on a evo16g but it was a smaller Tial so i wasnt sure if it mattered
Thanks alot
If i can think of anythign else or have any questions i will be back to post
Thanks alot
