2G Tial wastegate install
bmw335ikt
228
16
Sep 23, 2015
Crown Point, Indiana
Hello, I have the punishment racing recirculating o2 with tial mvs wastegate.
How to you hook up the wastegate. Where do the lines go?
I'm runing a 68hta with fp manifold
Pics would be great
Thanks
How many lines run from the wastegate? How many are blocked, and where do the lines run to?
I'm also running the aem tru boost electronic boost controller
Thanks
i was looking at that. can i run it like that in the pic. from the wastegate to the intercooler piping. or does it have to be connected to the boost controller
i also found this dont know if it has to be ran like this where to top is not vented
I believe if youre just going to run spring pressure then you don't have to have a boost controller and you can leave the top one vented. if you're going to run more than spring pressure then you need the mbc connected to the top
