Tial 38mm Question
SFRacingGST
235
May 4, 2004
Warren, Rhode Island
OK, i hooked up my greddy boost controler today. Can some please let me know if i hooked this up right. I ran a line from the nipple on the turbo to the boost controler, and then from the controler to the top nipple of the wastegate.
I know i got the boost controler hooked up right but is the rest ok?
Thanks bro, starting up tommrrow for the 1st time after the build.. Alittle nervous right now and just double checking some wiring and other things to eliminate problems
No you run it to the nipple on the side. Just vent the top nipple. I had mine on the top nipple and it was infinite boost. It needs to be to the side nipple.
While thats correct if your running a MBC, thats not always correct for an EBC. Alot of EBC's can be hooked up to different ways. That would be the correct way if the OP has the solinoid hooked up using the NO connection. If he has the solinoid hooked up to the NC connection, then you want to run to the top fitting on the Tial.
Oh ok thanks for clearing that up. I have never used a ebc before so thats good info.:thumb:
It sounds as though he's only running one hose though, so it would be to the side nipple. The instructions for setting it up with an electronic controller are on their site.
http://www.tialsport.com/techincal.htm
