Tial 38mm question bar spring.
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
Looking at getting tial 38mm WG from SBR and i have some questions.
1.First one does it matter if i get the standard silicone nomex diaphragm or the extreme silicone nomex diaphragm , and whats the difference.
2. for WG flange do i need the inlet and outlet flnage.
3. and what spring pressure should i get, does it go by how much psi i am running, so would it be the 1.6
heres the info: http://www.slowboyracing.com/more.php?id=127&
thanks
gamingguru said:
I would get the spring that is rated for the least ammount of boost that you want to run.
Your question was already answered by this guy. If 25 psi is the minimum you want to run then get the springs that equal out to 25 psi (1 bar and .7 bar)
