Tial 38MM?
TurboDSMer
174
Dec 2, 2003
Burlington, Massachusetts
I am currently running an EVO 16g and am going to add an external wastegate to stop my boost from creeping to 28psi y 6000rpm's. My question is this will a tial 38mm wastegate be able to handle either a Buschur 20g or a FPGreen? I plan to run at least 20psi on pump with either if those turbo's. Thanks Sean.
I run a 38mm on my 50 trim and it holds just fine. So it should definately suit your needs
The only problem that you could possible run into is the wastegate not being able to let off enough exhaust gas giving you boost creep. But with the turbos you listed I don't forsee this being a problem
  • For sale Evo 8 steering wheel with dsm adapter welded on.
    Evo 8 wheel with welded adapter for dsm
    • 98TalonPandaTSI
