Throttle cable issues( removed cruise control)
evolveddsm
34
Sep 22, 2005
Oceanside, California
Doing a little buildup on a 97GSX. Long story short we have removed the factory cruise control, but are now faced with needing a throttle cable.
Anyone have one sitting around they would like to sell. Or does anyone know where I can pick one up without being raped by Mitsu parts department?
Since we are on the subject of things I need, here are a couple other parts I could really use.
Oil filter relocation kit
Ground effects for a GSX, passenger door. (not the side skirt, but the little plastic piece that mounts directly to the door.
Unless you mangled the throttle cable, you don't need to replace the throttle cable when you remove the cruise control. You leave the box that attaches the pedal throttle cable to the cruise control. You can remove just the wire going to the cruise controller control box. If all else fails, order the non cruise control throttle cable on-line, it's only $45.
http://www.slowboyracing.com/more.php?id=5420&mods=21-9354
Sounds like www.jnztuning.com has everything you need. they sell the throttle cable for less then 35$ and they also have the door caps you are looking for i believe and the oil filter relocation kit. Not to mention great service.
good luck and I think thats the answer you were looking for...
I am driving a Talon Tsi with cruise control and I am having problems with my throttle cable. It is to short? I have put the two screw as far towards the throttle body as I can but still. I took it out and it isnt binding or stuck or anything? I have no idea unless cable shrink, LOL. I was wanting to get rid of the cruise control and box but dont really no how. People say that you should just stick in a non cruise control cable but where do you bolt it down? Firewall? Does anyone have any pics of theres installed?
http://www.dsmtuners.com/forums/showthread.php?t=257519&highlight=non+cruise+cable
