Throttle Body Spacer
greenmeanie99
237
Feb 3, 2005
Lancaster, Pennsylvania
I am just browsing ebay and I found an OBX throttle body spacer.... I don't know how it would help perfomanec but its only $40. Will this even make a slight increase of power.
When you run across a product like this, just ask yourself, "Are all the tuners clamoring for this item?"
You've heard of the things that work. Conversely, if you've not heard of them, they're probably horsecrap.
the only effect you head from the spacer is a ricey blow off valve sound.. When you tap the gas the air hits the spacer and spins causing a high pitched BOV like sound. Actually sounds good, but ya no performance value.
What? how do you get a BOV sound when you hit the gas? I'd expect a whistle or something from it. Its stupid... just get your TB bored out. You'll deffinatly notice a differance from that.
