GRace
- 147
- 2
- Jan 25, 2011
Joplin,
Missouri
My tb vac ports are blocked off right now. Out of the a1, a2, e, and p ports, which one is connected after the throttle plate? I'm trying to find a place to connect my map sensor and if one of those ports connects straight to the manifold it should work just as well as tapping somewhere else.
If that doesn't work then I will hook my boost gauge to the tb and use the T from the fpr line as map line.
