2G Throttle Body VAC ports
CyberEye
947
4
Jun 25, 2002
2g, has three vac ports on throttle body. A, E, and P. Which of these ports lead to the outside of the throttle plate? IE: Will see boost in the UICP.
I'm asking because I installed my 1g bov that was modded (vac mod) and I don't have a pressure outlet nipple on my turbo (16g) to hook the new source on the bov too.
Drill a hole in your IC pipe or J Pipe and put a 1/8NPT fitting that has a barbed end. You can also buy a fitting that will pop into the IC coupler hose if you don't want to drill a hole in your hard pipes.
I'll probably just do this. I need to take my J-pipe off anywyas.
karbon said:
Good idea. It's way easier than getting a tee fitting at autozone and a couple feet of vacuum hose. Good luck.
I remember reding some where that it has to be before the TB but don't remember why.
I have several t fittings and a good 20 feet of hose :|
