thread tapping question
IrishBeatdown
585
5
Feb 3, 2012
Tucson, Arizona
Bleh, so I was making some modifications to my intake manifold, specifically where the vacuum line from the bov connects to the im. I wanted to run a stainless line in its place, so i decided to drill and tap the manifold to accept a 1/8 NPT to -4AN fitting. Drilled the hole to 21/64". Went to go thread in the fitting, and the hole is too large, to the point where the fitting barely goes in but isnt threading. I used a 1/8 - 27 NPT tap. What in the living hell? Did i need to use a different tap for this fitting? I'm damn confused, maybe someone could shed some light on this. Going to have to weld in the fitting now. :banghead:
That is the correct size bit and tap for that fitting, it should work. As long as you're sure that is the bit size you used and you have the right fitting, I don't see how it couldn't fit right. Did you hold the drill bit up to the fitting and make certain it wasn't too big?
So is the hole too big and you obviously can't go back or is it too small and the threads aren't catching exactly. Sorry this bit got me mixed up.
Cool idea though I bet it'll look great afterwards
The hole is tapped cleanly, the fitting is just too small for it. Hole is too large.
So I re-checked the sizes, the drill bit is dead on accurate according to my calipers. I checked size of my fittings, I have a bunch of 1/8 NPT fittings lying around, they are all .38" OD, the tap is .42" OD though. I'm starting to think this tap is labeled wrong, it clearly says 1/8 -27 on the side, but my calipers say it is too big. It was from a cheapy tap - die set. So at this point im going to go ahead and say this tap is a piece of crap mislabled whoremother until someone else can refute it.
Did you use a drill/tap set specifically for heli-coil? They will often label the parts with the next size down because thats the bolt size you will use, not how large the actual heli-coil (and hole) will be.
Shot in the dark, but possible.
No, this is off just a regular tap/die set. I'm about to throw the whole set in the trash, serves me right for buying a 20$ set off of amazon and being a cheapass.
Thats the thing with NPT taps, go too far and it becomes to large.
Tap a little, then test fit the fitting, untill you get it where you want.
Sonds like you may want to take the hole to a 1/4 NPT, then install a reducer bushing for the 1/8 NPT
going to have to do something else, i dont think i have enough space to go to 1/4" as this is on the raised port of the stock 2g intake manifold. most likely welding. i need to chill out with the tap next time i guess.
Yeah slow down there happy feet and don't tap so much next time ;) LOL my why don't you post a pic so we can see how much room you have? But i think i know why your saying weld it
A couple options, you could get a new IM off the classifieds they seem pretty cheap. Or buy a 1/4 npt aluminum bung to weld onto the manifold, like an exhaust bung for a wideband. Or just weld like your saying :)
In my machine shop the rule of thumb for npt's is tap 6 threads from the top. So from the big end of tap count down 6 threads and tap to that point. In 15 yrs I have never been screwed with this method. Even with some of my customers who check our parts with thread gauges ,never a problem.
I'm going to weld a bung on. For some reason im opposed to buying stock parts for my car as a replacement if I don't have to, I feel like the ones I have belong to my ride. I'd rather fix than abandon. My head, for instance, the previous owner stripped the ever loving shit out of the exhaust mani stud holes, even tapped one to m10 and stripped that. Would have been cheaper to buy a new head, but i coiled a few of the holes myself and paid to have the m10 hole fixed at the machine shop so i could keep it.
