Thread a stripped bolt to a smaller size?
PrimerPLus
1,160
20
Jul 28, 2011
Tokyo, Asia
One of my carrier bearing studs have been stripped. It will go all the way up and soon as it gets tight it pops. So I tried rethreading it to the same size. M10 x 1.25 Same issue. I even tried 2 brand new nuts and no change. So I was wondering if it would be an option to get a die that can do M10 X 1.00 or maybe go smaller bolt size with a M8 x 1.25.
I just don't want it to be unsafe. I am trying my very best to not have to cut it out and weld a new one in.
Why don't you just use a couple of washers so the nut will stop in a place that has good threads?
Pretty sure. I bought 2 brand new nuts because that is what I thought the problem was too.
Oh, well then I would try using a die on it and rethreading the entire thing. But if that fails then you will have to get a stud welded on there.
Yah thats what I was wondering. I used a die and threaded it back to a m10 x 1.25
But would it be ok to go to a smaller thread? m8 x 1.25
I used the die as colt suggested along with a new washer and lock but. Worked perfect.
  • Wanted 6 bolt NT water pipe
    • chrisman287
