T-Bolt clamp size for radiator hoses
PrimerPLus
1,160
20
Jul 28, 2011
Tokyo, Asia
I ordered some T-Bolt clamps for my radiator hoses and they said they are 1.5-2.0"
My radiator hoses is 1 10/16" or 1 5/8"
The T bolt clamp all the way bottomed out measures 2"
So what am I supposed to get so that a Tbolt clamp will tighten down hard onto my radiator hose that is 1 5/8" diameter from outermost to outermost.
what ever they are if you have an OEM plastic tanked in/outlet equipped radiator don't use them at the radiator side of the connections, i've broken the neck off just tightening a regular hose clamp, a t=bolt would be sure to snap a stock radiator's plastic necks off the first time used. I have had the aluminum ones but they take up too much space and i get better cooling with OEM fans since they only fit with oem radiator along with a turbo of the size i run.
i have them on my hoses with no problem, but definitely look how on how much you tighten
and this is the size / number on my clamps.
CLAMPCO 94106-0162 1.62 inch
  • Wanted 6 bolt NT water pipe
    • chrisman287
