thoughts on upgrades
eagleturbo
55
Sep 28, 2012
lexington, North Carolina
hello everyone, OK my water pump went put on me, so now were doing the timing belt,water pump,balance shaft delete. a long with a few other parts like the 1g tb,camshafts, an the 14b turbo with the stock smic with a hard pipe for type s bov, 3in high flow cat and 3in exhaust from the turbo back and injen intake with filter. just trying to get you thoughts on the upgrade parts and what power increase could I see.
If you are replacing the turbo I'd look into the 16g. I believe the normal 16g won't require injectors or fuel pump upgrades if you plan to keep stock boost. I like their results, and they are pretty cheap too. Or you could go with the big 16g or evoIII if you wanted to get into those upgrades. Just my opinion.
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
