Those using non-OEM Clutch Master Cylinder
Do you use an OEM clutch master cylinder or a NON-OEM version?
  • OEM Clutch Master Cylinder
    Votes: 5 62.5%
  • NON-OEM Clutch Master Cylinder
    Votes: 3 37.5%
  • Total voters
    8
alice
309
Sep 7, 2006
Canandaigua, New York
I need to replace my master cylinder in my 2g AWD. I have read several posts around the forums about using non-OEM master cylinders like the Beck-Arnley or others. Many people say they end up replacing it within a few months especially those using a ACT2600 or larger or a twin disc. I just wanted to see if anyone is using a non-OEM master cylinder and if you have run into any issues with it. I will be running a non-OEM slave cylinder, full ss clutch line and a ACT2600 with OEM TOB.
Also, with the POLL, are you running a ACT2600 or larger clutch?
I have one from Autozone that i ran since i had my SBR3500, which is like an ACT 2600 and had zero issues.
OEM quality is always best, but i like the fact that Autozone has a warranty so incase it fails i just get another one free
oem im running an aftermarket one now what a pos. i have already bought my oem master and slave along with fulcrum and fork. gonna replace them all when i do my clutch.
i work for a mitsu dealer so actually my cost on everything was pretty cheap the master even ended up cheaper then the parts store one that i put on it. thats what i get for not checking first
