fstfcs
Banned Member
- 230
- 0
- May 5, 2009
Bowling Green,
Kentucky
Ok. So here i have a small list of issues/questions i need help with.
All input as well as opinions will be taken into consideration and put to use.
Problem #1
I was driving the car just fine. Parked it, went back out to drive it home.....and now my running lamps, license plate lamps, and interior night time lights (ie* gauges, ac/heat controls and such) are no longer illuminated with the headlights on. Now, i pulled the relay to the "lamps" and it clicks when plugged in, and i have switched it with about 4 other relays. So i ruled that out. I checked out all the fuses and replaced to be careful. Still nothing.
Help needed haha.
Question #1
I bought an oil pressure gauge. It came with an stainless oil line and fitting. I was wondering where you guys tap for these things. like maybe the most common/ easiest spots. So i can get it installed.
I have done some searching and came up with a thousand things. Some direct input would be great.
As well as pictures of said tapping for the oil pressure.
Problem #1
Help needed haha.
Question #1
