SmokeyGST
- 43
- 0
- May 22, 2004
Houston,
Texas
Well the engine rebuild started off smoothly everything came apart quick. and then got hung up on the head being the wrong one. I turned the crank around and it gave alot of resistance. I figure this is just because the walls have no oil and the rings are brand new. I got to turn the crank again 2 days later and it won't move, so i think oh no its siezed? so i loosen the rod caps so i can take the pistons out and when they are all lose i try to turn the crank again to see if the crank will move away enough to hammer the piston when suddenly it turns somewhat freely(no where near as free as before the pistons came out) Now i am figuring that the rod caps were over torqued and kept the crank from moving which seems pretty correct. THe chiltons said exact print "1990-1994(plus and additional 1/4 turn) 14.5ft/lbs
What that means to me is the torque wrench clicks and then i turn another 90 degrees, so this is what i did. I know have a rather large inkling that i have severely overtorqued the rod bearing caps, and would like some opinions on how bad what i have just done really is?
Cliff notes: Chiltons book told me to torque rod caps to around 75ft. lbs. Mayhem ensues.
