things i need for a 20g
96_AWDtalon
66
Nov 22, 2008
brookpark, Ohio
ok so i just bought a 20g and a manifold td05 and i was wondering what i need for this turbo so far i have a wideband, an afc 650cc injectors, a front mount. just wondering what else i need like do i need new oil lines, coolant lines, a j pipe, have no idea what else i need, any help would be useful
Thanks
Kevin
You will NOT need a Jpipe (providing it's a td06 comp cover), but you will need FMIC piping if you dont have. The oil/coolant lines are the same, they are both mitsu CHRAs. Do you have a logger? It depends on how much you want to get out of the 20g, but that should be a good start man.
You will definitely need a 255 fuel pump, and you may want to get a rewire kit to make sure you aren't straining your pump. The injectors should be ok, but you won't really know until you start tuning the car and cranking up the boost. Just make sure you get a good tuner like dsmlink, or EVOscan and do the proper supporting mods to handle the 20g.
