thickness of tires
aznlangjai69
89
Dec 15, 2003
vancouver,
hi, i was wondering if the thickness of the tire (255/45/18r) take effect over bumps. For example, my tires is a 45, and whenever i go over bumps, like train tracks, or cracked bumpy road, i can feel as if my shocks are blown or something, or my shocks are taking effect. if it was thicker, say 60... would it feel different or the same?
Sure, a 60 series tire will be a lot softer over bumps than a 45 series tire of similar diameters for the same reason it will not corner as well; flex. Perhaps you need to compromise.
agreed. but I just want to know how you managed 255 size tires without rubbing on your DSM. from what I've heard, and have, 235 is the closest to go; although 245 has been used before.
as wret stated before, the higher your sidewall the softer your cornering ability will be. or perhaps maybe your shocks are just blown :confused:
the smaller the middle number the harder the ride is, less rubber doesnt cushion it as much. i have 245/40/R18s on my 18x8 wheels, 45mm offset, no rubbing :)
the numbers i've given out was just example because i dont know what the middle number is called. thanks for the cornering advice as well, i didn't know that until now.
