thermal exhaust
The item description says 1st gen? Then I would assume it is specifically for a 1st gen and will NOT fit your 2nd gen. But hell, you might have a welder, a saw and the gumption to make it fit....
Wasnt there a thread just a little bit ago trying to do the same thing, but instead it was taking an exhaust from a 2g and putting it on a 1g ? LOL
Besides that unless you do like TwoLiterLaser said and chop it up and make it work it is not going to. It definately will not just bolt up. If you do have the equipment to cut it up and weld it together than you could probably get it to work. It would be worth doing if you can get the exhaust really cheap. :thumb:
