The Official "What Should I Spend Money On?" Thread [Merged 10-6]
$350 isnt too much to work with. I would probably keep the money for problems down the road, But if you hafto spend it.
manual boost controller $45?
Cheap boost gauge $50?
Fuel pump $95
just unbolt the exhaust if you're going to the track- free.
port everything - $10 if you do it yourself.
race gas - ?
you would still have like $160 left.
The "Scanmaster" from www.fullthrottlespeed.com. With this you can tune your soooo easily! It shows in real time knock, timing and about 25 other pieces of data along with a built in "g-Tech" so you can check 0-60MPH,1/8th mile and 1/4mile. The other $100. will be for the gas you burn playing with the scanmaster getting as much HP as you can squeeze out of it! Mark
1/10th mile-SOUTH BUTLER?
Yea, south buttler. I forgot i have a 60mm splitfire boost gauge, mbc-$20, $100 for full 3 inch mandrel bent, relay for rewire -$7, 4ga. wire should be free. Im going to gut the interior. Im not sure where to get my bottle filled so i may do without that. A friend said i should have a tubular 02 housing made and get one of the cheap tubular turbo manifolds (pacesetter) and have it rewelded and wrap everything in fiberglass header wrap (i have a 100foot spool of it. I also want to do something for a fmic and maybe use the fuel solonoid from my N2O kit to make an interchiller with brake line and c02 paintball tanks. I have my fathers parts store and few salvage yards at my disposal.
If you were wondering why im waisting my time it is because a local musclehead running a dyno'd 500hp (he carries the dyno slip everywhere) 65 elcamino w/ 383 stroker, challanged me that i couldn't build an import car by october that could beat him, and i told him that i could not only build a faster car, that i could also build one for less than $500. That figure included buying the car as well. And he said that if i could beat him with only $500 invested total he would give me $500, but if i lose i have to spend the rest of the night cleaning his car in a mini skirt. He saw the car when i bought it and knows that it is bone stock, and i have to show recipts for every mod i put on the car. He also said that i could use the parts i already have, but i had to tell him what those were, he is taking this very serious as am I. Im not going to cheat, this is an honorable challange and i think that i can build a faster car.
Also, i think he runs mid 6 sec in the 1/10... And he just changed to an auto trans with a stall converter (700R4 w/ 4800stall) i think.
You really got your hands full, I would think.
You bought the car and only have $500.00 to spend, To beat a 500hp car! I hope the car you bought is in perfect condition(Mechanically). But then again, There was a build up of the fwd car on a budget that is running in the 11's on the 14b. Either way, Good luck and keep us updated. I hope you do not hafto wear girls clothes in front of everyone, Especially if they do not know what is going on OMG
Well this is 500hp when it was in the stock car it came out with, and it also had a single 1200cfm holly dominator, now its in a truck with a dual 4 highrise and two 650 hollys, although i think he caught wind that i got the TSi running (which is running fine and seems to be in real nice shape mechanicaly, body wise its lacking) I will have pictures definetly
I also have a 91 tsi awd w/ auto trans and LSD which i might take to the track aswell
stupidest idea yet...
...and for the idiot that thinks he'll beat a 500hp car with $500 good luck on that one...I would believe maybe $3000 in mods not including the car but $500 including the car ya right... :laugh:
your talking about takeoff, thats what 1/10 mile is about, he could have 1000 horse, hes still not going to hook up like my awd dsm with rear lsd and a launch
When I suggested the "Scanmaster" I did not know the whole story. If you don't tune your motor you loose. This is a 528 ft. race. Man if this guy has a dyno slip for 500HP he must have slicks also. You're going to need 2 shifts to get thru that distance. I applaud you for your effort but you should have said something like for 1/3rd of what you havein yours...anyway when I saw turboville and then the 1/10 mile South butler came to mind. Post the date, maybe I'll show. Mark
You said it yourself, the only thing you've got going for you is AWD because such of a short race. Get that power to the ground with a 2600 ACT. It's a pain, but it sounds like the best investment for your situation.
SplitGSX said:
Tell him he has to run on street tires. :thumb:
hes got wrinkle walls... and traction bars, but his car is streetable, he drives it around once and a while
Also, i plan to part the car out after this so i dont want money into something like a clutch, any mod done to the car will likely get put over onto my 91 tsi awd thats automatic.
Since you dont care about the car fill it up with jp5 jet fuel and you should get maybe 1000 feet of run time before your motor melts. Really :thumb:
I like the rocket fuel tip. Only go with some112 leaded, it's available here. Then run the boost to 25 psi, just a down pipe. this guy doesn't drive an orange '69 Camaro does he?
You know that there is a guy that went to Wyo Tech that turned a 4 cylinder turbo-charged car into a 10 second car by just modding all of the stock parts. He only wanted to prove that it could be done.
Hopefully I'm not talking out my a$$, I think this is true.
Anyone else know what I'm talking about?
no he has a flat black 65 chevy elcamino, i will get cam2 to in watkins or 100oc leaded fuel at the airfeild. prolly 20 psi with modded intercooler pipes. 3 inch all the way back with a cheap 3 inch flex joint, im not sure about a muffler yet
this is the dumbest post I have ever read. Seriously who races 1/10th mile???? That's around the 330 foot mark. If you just want fast takeoff you need a good clutch and exhaust.
i would buy a $350 huge carbon fiber/aluminum wing because you will gain the most performance due to downforce, but mount it on the root so it distributes it evenly between front and rear
here we were having 8th mile drags at autocity up in flint and the winner was a 2g fwd against a 427 vet with 10" drag slicks because the vet spun them bad as hell. the 2g was def. modded to the teeth way over 500 bucks good luck though i hope you make a good name for 4g63s
your a ####en moron give that guy 500 dollars for wasting his time
there is so many ####en retards on this board it makes me sick
his car is ATLEAST an 11 sec car
there is no way in hell u can do that maybe if you strip your car down to 1500 pounds
RETARD! kids like u should be SHOT!
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
