The car dies during boost *logs inside*
chavez408
1,115
Dec 13, 2003
Bay Area, California
Well, I was going to mess with the car today to see if I can post a log and start tunning. So after replacing the front o2 sensor via dsmlink (code 11?). To cut the story short, I started her up and let her warm up to normal temp. I began to drive away and began to capture a 2nd or a 3rd gear pull ( I forget). Right as I began to hit boost (15 plus psi) The car felt like if I hit fuel cut, it almost felt like i ran into a brick wall. The anti lock went on and the car died. After a few minutes of me letting her cool down I began to drive away and she wouldnt go into boost at all. I barely made it home with it dying on me multiple times. It wouldnt even speed up to 30 mph.
Here are a few logs that the gf capture. I guess she capture more than one. The first one is an iddle log (iddlelog623.dat) before I did the 2nd or 3rd gear pull, the second one is the pull, the third one is the cruise home (dsmdown.dat) after finnaly her starting up for me, and finally the fourth one is when I made it home and let her iddle for minute before I shut her down (shittyidle.dat). I dont know what it could be wrong? I haved replaced all hoses and tighten all t clamps and bolts. I have not yet check if my knock sensor is oozing but I will later tonight.
EDIT>>> She never log the pull. But she got the iddle logs and the ride home. She did the opposite of what I told her haha But I think she might of help me even more?
Logs posted
Haha fixed. Upper pipping slightly disconnected from the coupler. Thanks for all the help guys, hahaha. This can be close. I will re do another thread with better logs.
