The build list!
dsmornothing
603
12
Jul 23, 2009
Ishpeming, Michigan
Engine:
Manley 9:1 coated pistons
Manley H-beam Rods
King high performance main and rod bearings
Sim 275 Race Cams
Balance shaft elimination
Full port and polish
New ITM valves
5 Angle valve Grind
Manley springs.
ARP Head studs
ARP Main studs
ARP Rod bolts
Prothane motor mounts
Fuel:
Rewired walbro 255
Bosch 044 inline
SBR 1000cc injectors
Aeromotive AFPR with install kit
Tuning:
PLX wideband
DSMLink v3
Turbo:
Holset Hx35 8 blade
Stock T3 housing
T3 manifold
Tial 38mm Wastegate
Driveline:
TRE stage 2.5 transmission with welded center diff and rip grip front
Act 6 puck unsprung with a 2900 Pressure plate
tkstoygsx;bt9082 said:
this setup installed or in the process? should put out some decent power with the right tune? you doing the build yourself
There is some pictures up on my other entry. And yes i am doing the build myself, granted im getting alot of help from my sponsor Strictly Import Motorsports. and yes it should put down some good power, Im looking into a Borg warner or garrett for next year maybe break 600hp.
