1G Testing Radiator fan
Jumping the motor & seeing if it runs is a good test.
Amp draw on it is another good test.
Another is to jump the fan motor to ground of a battery on the appropriate fan terminal.
On the power side of the fan, hook up a test light & other end of test light to positive battery.
You can now spin the fan over by hand & check all the commutators of the fan motor to see if their all good.
Spinning the motor over slowly you will see the test light light brightly when making connections & off when the brush is moving over to the next commutator on the motor.
A non-lighting or dim segment indicates a worn out fan motor.
