lccynmbr13
- 232
- 0
- Sep 10, 2006
Renton,
Washington
I've posted here a few times trying to find the answer and spent quite a few dollars trying to fix the problem. Here's the scenario. Driving down the street in 2nd gear, maybe 3rd, and on a rare case 4th or 5th. Upon acceleration the car quits pulling with the feeling like that of a clutch slipping yet the RPM's don't spike like when the clutch slips. It doesn't cough or sputter, nor can I hear the ping of knock. That's about the best way I can explain the way it feels. I look in the rearview mirror to see if I can see funny smoke but never see anything unusual. The car has somewhat of a miss when idling about every 10 to 20 seconds yet this too is random. I took it to a very reputable DSM shop to have a boost leak test done and we found that some clamps were loose on the underside of the SMIC and the injector o-rings were toast and some boost was leaking from there. After fixing that and verifying there were no more leaks that same day the car suffered the same lag. The clutch felt funny and after about 2 more weeks the clutch actually started slipping so I said ok maybe it was just the first signs of clutch wear and now it's completley going... So I swapped out the stock clutch for an ACT 2600 and had the flywheel resurfaced all work again being done by the same shop. You guess it, it still had the same problem. So I got pissed and decided I could maybe have a leaky BOV so I got a 1g BOV and actually got a noticeable power gain so I figured that solved my problem. 3 days later it lagged out again. I have brand new NGK plugs correctly gapped, new factory plug wires, and I run 92 octane gas. Everything other than the BOV, UICP, and K&N filter is stock. No MBC, but did take out the BCS restrictor but it lagged before I took the restrictor out. I don't have a boost guage so I couldn't tell you what PSI I'm running at when the problem occurs. What could be causing this?
Not to be an ass but I'd appreciate it if new members didn't chip in with little ideas they came up with but have never actually had any experience with this sort of problem, and let me repeat I DO have new plugs, wires, and have had a boost leak test done.
Thanks for reading my novel!
