temps senser bad?
brandonclum
136
May 20, 2009
spokane, Washington
Ok guys easy/dumb question. If my temp sensor was bad would it throw a code and would it make it have idle surge I did a resistance check on it while the car was cool and it read 1.5 k ohms so I dont know. Also would a bad o2 make the car idle surge I also have a broken flex pipe at down pipe (going to fix asap). Sorry I know dumb question but I'm feeling like I may be missing something.:mad: 1g dsm
Ok turns out i have a bad throttle closed switch I unplug it and the car runs perfect i plug it in and idle surge. Since you have to buy them with the tps if you can find them, If i decided to run with out it plugged in will it be ok to do that?
