TB Spacer issue????
streetlegends
319
9
Sep 7, 2005
Lawton, Oklahoma
I was wondering has anyone had any install problems mainly the throttle cable with the install on a 4g64 and I think the 4g63T has the same throttle body correct me if I am wrong. Well I had just received mine and first off my bolts are tooo short and secondly my throttle cable is short about and inch. Any ideals on how to correct this problem would be greatly appreciated!! Oh and one more thing what length of bolt will I need if you know please let me know.
I have not had any experience with throttle body spacers, but can't you just pull the bolts out and replace them with a longer one?? I assume they are 8mm bolts, which would fit a 12mm wrench. Just measure the full width of the throttle body with the new spacer on it, that will give you a good idea. Then just buy the bolt 1/2 - 3/4" longer. If you can't find what you are needing PM me and I will send you the bolts you need. I've got unlimited supplies of bolts and nuts.
Thanks I know that you can't just buy any bolts to stick on there. The bolts that came with the TB spacer are the same as the stock and I dont understand that part because they should know that u need aleast 3/4 inch added to it maybe even 1 in because it's and inch thick added to that area. My main issue is the throttle how to do that I being busting my brain and knuckles trying to figure out what to do.
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
