Taylor 8mm or Magnecore 8.5mm wire? Difference?
jt1583
86
Mar 24, 2004
alpharetta, Georgia
Will it make a noticable (5+ hp) by using the magnecore 8.5mm wires over the taylor 8mm wires? The price difference is about $25 and i would definetly rather use that somewhere else if i can. Thanks
smartass.
Generally i havent seen a difference in plug wires. I mean, theres your cheap, stock 7mm wires, and theres your nicer 8.5mm NGK wires. At Higher HP levels there will be a difference. If we're comparing 2 decent sets of wires to eachother which are basically the same size, then no...you will not see a difference. There is currently debate on whether there is a noticable difference on 7mm to 8.5mm wires.
