Tap Oil Filter Housing For Turbo Feed?
sweet97
2,386
18
Mar 6, 2004
auburn, New York
I have a Forced Performance turbo oil inlet braided ss oil inlet line. It is supposed to pick up the oil from the oil filter housing. The line has what measures to be a 1/2 brass elbow to thread in. I would guess there is a plug to remove from the housing that this 1/2" pipe thread elbow would thread into. Can anyone direct me to the location of this plug?? I'm changing turbo's and ex. manifold and am half way through, darkness has set but having a jump on tomorrow's work would be appeciated. Thanks, Mark
theres only 2 plugs there that you can take out on the oil filter housing. youll need an allen wrench or hex socket to remove it. Youll want to remove the upper plug for your 93' talon. If you can change your oil filter then you can find it ;)
Cable fed I asked for the location of the plug. What's the response about takng something apart?
heres a pic from RRE sweet97
