2G talon wont build more then 15lbs of boost
Chedda
Oct 19, 2013
Richlands, North Carolina
I have done boost leak tests, rebuilt turbo,new fitting on the intercooler pipes, new boost controller. I dont know what is causing my car not to build more then 15lbs of boost it spools up just fine. I can hear the wastegate open and i have a 14lb spring in my 38mm wastegate. Timeing is perfect so is fuel trim. I do have an intake manifold leak but would that cause it not to build boost and help would be great.
I will try the intake manifold gasket first. Also i am still not able to post in the other forums yet. If that dont fix it could my wastegate need rebuilding.
Ok sounds good. Its not a boost leak and i can hear the wastgate close at 14lbs thats the rated spring thats in it, what do you mean by exhaust leak it have brand new metal gaskets on the manifold and the turbo side. I am really lost on this. I my self think its the wastegate but i can turn my BC up and will still only hit about 15psi
I know i have a big leak at the intake manifold but when do a BLT it holds everything
Ok will check tonight. Also took out for drive last night and noticed i can barley hear my wastegate....i do have a dump tube on it so i know its somthing.
whats ## exhaust setup and where is ## gauge tapped into
the hashtags above are supposed to say your. i dont know why they did that
