2G Talon taillights to eclipse
Greddylove
33
5
Jun 28, 2020
Marysville, Washington
Ok so I have a 96 talon and have taillights from 99 eclipse I’ve done full conversion but can’t remember what wire from talon is for the reverse lights. Any help. I have wires fed from eclipse back up into rear but need a reverse power source. Any help thank you. I don’t have anything Talon anymore and car currently apart so can’t test which wire is reverse either.
Can you not test the wires that are already there with a test light. Put the car in reverse with the key on. Here is what I got from the Haynes manual.
Problem is no engine in car. Therefore if I turn key on fuel goes all over etc. plus no transmission in car too
My Haynes manual covers Eclipse and Talon from 95 to 05 so the diagram I posted should help you. My car is in storage so I can not check my harness.
Another wat to check ... disconnect the fuel pump and put a jumper wire on the reverse switch plug. At the rear check the plug for continuity.?
  • Wanted 6 bolt NT water pipe
    • chrisman287
